Hi i'm converting my acoustic kit with an eDrumin 8. I want to know if anyone has managed to get Positional Sensing and Hotspot suppression to work properly with 1 ply mesh heads.
I'm currently using Remo Silentstroke on my snare, a Pearl Sensitone Steel. I have to mention the fact that I'm using a homemade centered trigger that could have some structural imperfection that could make the signal of the piezo not clean as it should to make eDrumin do the job.
The Positional Sensing feature works but... It seems like the eDrumin can't recognize the offset from the center till I'm hitting a lot far away from the center, I would say that it starts to recognize hits away from the center when I hit after the middle of the radius of the snare, if not more far, so i get a very little portion of drum to get positions.
About the Hotspot Suppression feature some time it works and some time it doesn't.
I will upgrade my homemade triggers anyway, but i would like to know how much of the fault is from the trigger and how much is because of the mesh head I'm using since I read that 2 ply mesh heads are recommended over 3 ply and 1 ply is not mentioned at all.
Another thing i think could help understand my situation is that i'm currently using polystyrene to decouple the piezo and the support of the trigger (i know it's not a good material to do so, it's a proprotype and i didn't have any other material) so i think there could be some vibration that disturb the signal.
Positional Sensing / Hotspot suppression
Re: Positional Sensing / Hotspot suppression
I have no experience with single ply mesh, so I can't comment on how well it works. Both the positional sensing and hotspot suppression were modeled on snares using 2 ply Roland mesh heads.
It's normal for off center to not kick in until about halfway to the edge, so I don't see that as a problem. And for hotspot suppression, make sure you don't crank up the suppression too high, because the feature prevents itself from completely swallowing up hits. That is to say that if the amount of suppression is too aggressive, it won't apply any suppression at all.
Wow I didn't expect an answer that fast!
As shown in the image, it starts to recognize the hits not at the center where i put the red dot.
So to make the positional sensing work, i have to put the green rectangle all to the right, in the edrumin settings, that seems quite strange to me. Also i have a very restricted area where the position varies. Anyway my snare is 14 inch, i don't know if it could be usefull to know.
Have you tried increasing the tension on the head?
