Treshold issues with Foot Triggers (On Trigger Drum Bass Gen3)
honeyPot
Post by honeyPot »
I've recently purchased OnTrigger Drum Bass Trigger : https://www.thomann.de/fr/on_trigger_ba ... r_jack.htm
They are great but they produce a high input and even if i put the treshold at the max value to avoid a maximum, even really quiet vibration are detected above the treshold, so i got a lot of unwanted hits.
I'm wondering if someone here had the same issue, if there's currently some solution like working on the velocity curve, or i'm missing the right type of trigger (i didn't see on edrumin a special Foot Trigger in the configuration)
The trigger has no settings so i can't set something about that directly on the trigger.
Thanks in advance
Re: Treshold issues with Foot Triggers (On Trigger Drum Bass Gen3)
The English version of that page says they have adjustable sensor pressure. Have you adjusted the pressure yet?
