Which Device for Expanding One Footswitch Input to Use with 2 Pedals
jawdfs
Post by jawdfs »
I need to convert one footswitch 1/4" input on a Yamaha CK88 so I can use it for a 1/4" volume/expression pedal and a 1/4" control change pedal for turning pages in Mainstage. Which product do you all recommend? Thanks!
Re: Which Device for Expanding One Footswitch Input to Use with 2 Pedals
Assuming any sound is going to be produced in software in Mainstage,.then the quattro is what you want. It will support up to 4 pedals. Why do you mention the keyboard?
jawdfs
Post by jawdfs »
Thanks! Mentioned the keyboard in case anyone knows of this device not working with it. You never know with Yamaha. They are very proprietary with their pedals!
