Hi
skelmy
Hi
Post by skelmy »
I am new here just upgrading from a 61 key semi weighted keyboard to an 88key hammer weighted controller and wanted to buy your MIDI Expression Quattro converter to use with a Roland RPU-3 triple grand piano style pedal (I also play guitar and I have other pedals as well as I play the drums and I have 2 spare Alesis hi hat pedals that I will also be using)
So I was wondering if the Roland RPU-3 triple grand piano style pedal http://www.roland.com/products/rpu-3/ is compatible with your MIDI Expression Quattro converter system.
Thanks for the help!! What you are doing is great there is nothing else like it around. :D
Re: Hi
That pedal will work fine. It's a bit of a shame that it's has three separate TS jacks. Using an adapter, however, you could combine two of the mono connectors into a single TRS jack so that it would only take up two of the inputs. Here's a link to the adapter.
http://www.ebay.ca/itm/Hosa-Technology- ... 3a986db479
skelmy
Re: Hi
Post by skelmy »
Great thanks for the reply and advice Rob.
I was wondering if this one is compatible I take it that it is. http://www.dv247.com/keyboards-and-midi ... tAodXI0JSQ
Would be fantastic to do what you said and have them just in 2 slots so as the other 2 slots are free for other use as I have 2 Alesis hi hat pedals I can use as I said before.
Thank you very much for the help rob.
:D
Re: Hi
Ya, that pedal would work fine.
skelmy
Re: Hi
Post by skelmy »
Fantastic. Thanks for the replies.
Look forwards to buying one of these soon and using it.
Cool :D
