Can you connect 20 piezos to an edrumin 10?
CapCrunch
Post by CapCrunch »
If you connect one piezo to the ring and another to the tip on each input could you use 20 triggers going to 20 different sounds? By the way, in my case I would be going into a Yamaha DTX Pro module. Thanks
Re: Can you connect 20 piezos to an edrumin 10?
The short answer is yes. One thing to keep in mind however, is that processing 10 dual mono inputs isn't as efficient as 10 stereo inputs. You should get about 8k samples/seconds / input if they are all stereo, but maybe only 5k samples/second when they are all dual mono. That's still pretty fast, but things like positional sensing, bell sense, and edge sense might not work as well.
CapCrunch
Post by CapCrunch »
That's good to know. Thanks!
