Notes are off by 1 starting from A#5
joshebosh
Post by joshebosh »
There's a misalignment on the notes... I'm on latest Beta 2.9.4
09-30-2024, 12-27-55.png (83.33 KiB) Viewed 639 times
joshebosh
Re: Notes are off by 1 starting from A#5
Post by joshebosh »
for what it's worth, the transformations are turned off...
So, I'm troubleshoot to further find behavior steps,
Cause the one-off issue is jumping around now it seems...
The note 94 to 96 jump is no longer happening...
it's now jumping a one-off here between 104 and 106
09-30-2024, 12-44-17.png (88 KiB) Viewed 638 times
joshebosh
Post by joshebosh »
after factory reset, it's now jumping between 116 and 118, skipping 117...
Still cannot determine pattern or cause
I have an idea of what the cause is. If you double click and enter your note numbers that way, that might be more reliable.
I was unable to reproduce the issue. How are you adjusting the note values? Are you using the mousewheel, arrows on the control, or dragging the control with your mouse?
joshebosh
Post by joshebosh »
I have generally always mouse dragged the note to quickly get close to note I want, then I arrow click to exact...
Oddly enough, after tinkering, It's almost like a self correcting intermittent behavior I have not been able to exactly replicate...
This one off thing has happen a few times over last couple versions, but I suppose this is first time I mentioning it...
As a telecom software engineer, I'm usually pretty good at providing replication step, once I narrow it down myself...
When I say self correcting intermittent, It kinda like this, the device will hit that one-off state, either after flash update, power cycle, or somehow happens once in a blue moon... I step my mouse down/up hitting pedal each time to find where the one off count is spotted... it may shift to some other spot once I get there... but by the time I cycle all the way up or down, or click other various parts of GUI somehow things evetually jumps back on track and problem goes away, so I stop pursuit...
I'll keep my eye out for it again for narrowed replication... and try the manual keyboard input. I guess I was unware that was possible...
