Acustic drums and mics as inputs
Bassindaniel
Post by Bassindaniel »
Hi! Very basic question here.
can i connect an acustic drum Shure sm57 as trigger with this product?
Re: Acustic mics as inputs
Maybe if it went to through a preamp, but I'm not sure.
Bassindaniel
Re: Acustic drums and mics as inputs
basically i need to trigger 3 drums and convert it to midi.
You might want to look at DSPTrigger for that.
https://www.audiofront.net/dspTrigger.php
Bassindaniel
And if I’ll connect an piezo mic and tape it to a drum?
ELEGENT DRUM
Post by ELEGENT DRUM »
My guess is this will be a future product. There are many software products on the market that are good at converting audio to MIDI.
If Audiofront did it, I bet it would work better than the others.
