MIDI Expression 2.9.4 BETA is available
MIDI Expression 2.9.4 BETA is available for testing.
New Features
  • Port Filters (MIDI Expression iO only).
  • Send SysEx Messages (not available on single input device).
  • Send System Realtime (start, continue, stop).
  • Set status LED normally on / off.
  • Set the MIDI Note Naming Standard.
  • Move Marshall footswitch to its own pedal type.
  • Transform CC messages to 7bit pitchbend.
Bug Fixes since version 2.9.3
  • Fixed an issue with receiving sysEx messages via MIDI Expression iO DIN MIDI in.
  • Fixed crash on closing (Linux).
  • Added a fix to help recover devices that are having trouble updating.
ME_Control_PC_2.9.4.6.zip
ME_Control_MAC_2.9.4.6.zip
ME_Control_LINUX_2.9.4.6.zip
08-18-2024, 15-51-42.png (143.51 KiB) Viewed 2022 times
08-18-2024, 15-52-29.png (108.64 KiB) Viewed 2022 times
08-18-2024, 15-53-34.png (184.69 KiB) Viewed 2022 times
Audioproduction
Re: MIDI Expression 2.9.4 BETA is available
Post by Audioproduction »
I installed and tested the new firmware.
Port filtering and realtime system messages sending seem to work well. I didn't test sysex messages.
Unfortunately, the transformer option for transposing Value 2 (velocity) of Note On/Off messages that was implemented in 2.9.3.17 is no longer available ?
Regarding the Advanced Mode setting, I agree that it could be easier for basic users to hide advanced options. The potential issue I see is that in normal mode, you won't notice any active filtering or transformer settings which could be confusing.
Audioproduction wrote:
Sun Aug 25, 2024 4:27 pm
Are you sure? I just checked here and it's still showing in the UI.
Audioproduction
My apologies, your are right and I found the cause of the confusion.
All previous device settings remained the same in the UI after installation of the control application 2.9.4.0 except for Value 2 of the Note On/Off transformer rule which was reverted to INV. It is only after uprading the device to firmware 2.9.4.0 and retoggling Value 2 that the incremental option reappeared in the UI.
No big deal, here are screenshots of the sequence if that's any value for you.
Thanks for confirming. The reason it went missing was likely related to some other bug that was fixed in one of the last few builds of version 2.9.3.x.
Posted build 4
  • Added transform to 7bit pitchbend
  • Moved Marshall 90010 to its own pedal type
  • Improved some footswitch graphics.
Posted build 6
  • Fixed regression issue reading sustain pedals.
  • Fixed regression display issue with triple switch pedals.
  • Fixed toggle button layout issues with some pedal types.
