Using DSP Trigger with Multi Pad
Dxtrinc
Post by Dxtrinc »
Hello!
I was curious if anyone has used the software with a multipad to improve triggering?
I have a Kat Multipad and the triggering has extremely limited settings, basically only gain.
Can I hook up the midi and run it into DSP Trigger to have a few more options for settings?
Thanks!
Re: Using DSP Trigger with Multi Pad
No, DSP TRIGGER doesn't work that way.
