How to make a diy three zone cymbal with piezo
loverchese
Post by loverchese »
Hi so I am making a diy two input 3 zone cymbal with 2 piezos and 1 switch and so far I have the bow and edge working perfectly. The bell jack works independently as an individual pad, but when I hook it up as a slave to the three zone cymbal preset, it only recognizes the bow and edge, its not picking up any bell threshold. Do I need some sort of connection between the inputs? How is the wiring supposed to work on a three zone piezo piezo switch cymbal
Re: How to make a diy three zone cymbal with piezo
You almostly certainly have the bell piezo wired to the tip connection, but it should Infact be wired to the ring.
