Edrumin10 feeding 2 laptops
Mr_Bluesguy
Post by Mr_Bluesguy »
Is it possible for an edrumin10 to be connected two two separate laptops running different VST's with a splitter to run both simultaneously, or must a switch be used to select routing to one laptop at a time? an ED4 is feeding the ED10 host port Couldn't find this topic addressed in forum history.
Re: Edrumin10 feeding 2 laptops
You could have the ED10 connected via USB to one laptop and connected to the other via the eDRUMin MIDI out and into a MIDI in port on an audio interface, connected to the second laptop.
