I just received my 10 yesterday and amazed how quickly I got everything up. Except the snare which I use a XP120SD.
Anyone able to assist with the settings or even a preset?
Thank You!
Help with Yamaha XP120SD
Re: Help with Yamaha XP120SD
Did you choose the preset for Yamaha 3 zones pad from the drop down menu?
I had a similar pad and never had any trouble.
Yea, I did. I must be missing something because SSD & Superior Drummer doesn't register the rim click. Also iffy on the rimshots, although I admit the calibration helped a ton there.
