Edrumin with dwe hub
Rodd
Post by Rodd »
Will the usb host port on the eDrumin 8 work with the dwe wireless hub? I keep hoping dwe/roland will release some new pads for the dwe kit, but they haven’t. Plus this would likely be a more economical way to add some triggers for things like cowbells or wood blocks.
Rodd
Re: Edrumin with dwe hub
Post by Rodd »
not that it's a solution to my original question, but Soundworks 1.1.0 now supports multiple midi inputs. So that takes care of my need to aggregate edrumin with the dwe hub! I wasn't sure they were going to do that since I figured they want you to use the dwe kit with it, but then again it is a standalone application so I guess that makes sense.
