Going to purchase edrumin8 alongside my edrumin10.
Are there usb hubs out there that perform better, especially transfer speeds for drum interfaces than cheaper hubs used to connect keyboards and other peripherals?
best usb hub?
Re: best usb hub?
I don't think the brand makes that much difference to be honest. Just make sure it's a 4-port hub. If you're only going to be using an ED8 with an ED10, you don't need to a hub at all.
Re: best usb hub?
aaah forgot about daisy chaining daah....
- eDrumin Daisy Chaining.jpg (61.81 KiB) Viewed 1532 times
