Double triggering
Double triggering
Got a newly setup Gong Tom that double triggers when hitting it. How do I fix that? Tried messing w/ threshold and gain but it still double triggers. It is a 22 inch kick drum cut down to 5.5 inches, basically like a pancake gong tom. it did not double trigger when I was using it as a kick drum.
Re: Double triggering
Yet again, I think I just realized the issue. It appears I just needed to adjust the Decay based on something in the manual where it said if that is set to high or low it can cause double hits. I think I"m good here.
You definitely should check out this video:
https://youtu.be/v9_w32TWKZ0
Will check it out Rob. thanks!
