Key Stoke option not seniding modifier keys?
joshebosh
Post by joshebosh »
I have AutoHotkey installed which is capable of handling combos like "Ctrl+Alt+Win+L" to do awesome things.
However, the ME Quattro does not appear to sending out the modifier keys??
When I assign just a letter, A through Z the ME will out the character
But when assigning a modifier like Ctrl, Alt, Win, Shift, nothing happens.
When trying "Shift+R" in ME, i still get lower case "r" in notepad
I assign ME to do "Win+r" to bring windows Run prompt, nothing happens
I try any modifier plus letter, nothing happens..
Any tips on this? Devices is et for MIDI + Control Interface + Keyboard
joshebosh
Re: Key Stoke option not seniding modifier keys?
Post by joshebosh »
and I dont see any action happening in the ME logs area either, just the flashing device icon up top like it definitely knows the button was preseed
It definitely used to work. I'll check it out today.
I just tested 'Alt-Tab' and 'Shift A' and both worked as expected.
joshebosh
Post by joshebosh »
ok, I think i found I've narrowed the issue...
Seems the Key Stroke does not on the right side when using the dual switch.
Can you please test that?
Confirmed bug. I'm on it.
Fixed for the next build.
joshebosh
Post by joshebosh »
awesome thanks... will look forward to next beta...
As a workaround, if you set the first switch to Dual Key stroke and then set any modifier on the second of its two key strokes, and then switch it back to a normal key. The second switch should start sending its modifiers.
I posted build 13 with the fix.
