deleted (because everything is fine with the latest eDi version)
Cartman1227
Post by Cartman1227 »
deleted (because everything is fine with the latest eDi version: there is no missing notes bug)
Re: buggy v2.3.1.16 VH-10 pad behavior : missing soft notes
To be honest, it just sounds like you don't have your decay control set optimally.
Cartman1227
Yes, it was the decay. Thank you :) .
Btw, is there a chance to get the velocity curves set to linear by mouse / shortcut /combination?
