Drum Map Editor question
I currently have a drum map for Addictive Drums labeled Addictive Drums copy and sent to eDrumin and is saved in User Presets. see pic.
Questions:
1. if exported to my computer, how is this file imported back to eDrumin?
2. I am trying a free trial of EZDrummer, i will want to create another drum map preset. Can I assume i can select the Superior Drum Map Preset?
Screen Shot 2024-04-12 at 10.18.46 AM.png (234.52 KiB) Viewed 624 times
Re: Drum Map Editor question
1. You drag and drop it on the preset manager.
2. It should get you most of the way. You'll have to try and see.
thankx Rob !
