Using Double pedal triggers?
attached is my DIY design for kick pedal trigger. Basically, T-Track, PinTech top trigger, Strong-Tie plate (very bendable). I had T-Track laying around from my internal kick drum design. T-Track allow adjustability forware or aft under the foot board. I had a Pintech trigger, and though would be better since it has a beefy housing. Foam right now using MrClean majik eraser. Waiting for the real round poron foam. but, works great the way you see it. I built one for each kick pedal.
Do i gain anything using 2 inputs for 2 kick triggers vs just 1 input using a splitter for both?
I'm not a metal drummer so don't play 900 hundred miles an hour LOL.
Thankx
Re: Using Double pedal triggers?
If you got enough inputs, then just use one input for each, but you certainly won't lose any performance by hooking them up together using a splitter.
Thankx Rob 👍
