I have an ED8+ED4+Ez drummer3 setup. My ride is an 18" Lemon. I use it with the two-cables Roland configuration. The problem is that hitting the bell it works quite fine, but occasionally I get edge sound, mainly at harder hits (also the edge note lit up on the CA in this cases). Maybe my Lemon is faulty, but I wanted to give it a try here also.
Anybody had such problem with the Lemon rides?
Lemon 18" ride problem
Re: Lemon 18" ride problem
What firmware are you using? I recently made changes to help with the many mechanical issues on those Lemon cymbals. Maybe give build 20 (not 22) a try from the BETA thread.
viewtopic.php?f=29&t=2028
Thanks Rob, I'll try it. I think I'm using build 17.
I tried it with build 20 but the problem was the same. Any other idea?
For me it seems that the edge switch is too sensitive so it's perhaps a HW issue of the Lemon. I'm thinking of ordering a second piece of Lemon 18".
Anybody? Nobody experienced something like this?
My Lemon 18" ride works fine, so it is likely a hardware issue. Perhaps I can add an advanced control to in the next version to adjust for the sensitivity of the switch. It's already half backed into the firmware, but yet to be fully fleshed out.
Thanks Rob, my next 18" is coming so hopefully I'll be able to solve this issue but maybe your mod would be great for similar problems.
It's a tough call. There needs to be a balance between simplicity and configurability. I can probably hide that control and only make it visible for users who have advanced mode enabled. Let me know how the new ride performs.
Another week or two before it arrives. I'll let you know then.
sorry for the long waiting time, the second Lemon 18" arrived a little later than I expected.
The new Lemon behaved the same way like the previous one, so I have made some tests comparing the behaviour of the Lemon 18" with my Roland TD-20 and the edrumin. The results can be seen on the attached image. No offense here at all, I only wanted to let you know what I experienced and maybe these results can help you in future refinements if any is needed.
Now I am using the Lemon with a cable outside the rack tube and with the Yamaha adapter (to spare 1 input ). It is totally acceptable for me this way.
(The interesting part is that the edrumin is somehow sensitive to cabling as it handles the Lemon way worse if the trigger cable runs inside the rack tube. I don't know if it makes any sense...)
- Ride_behaviour_test.png (157.04 KiB) Viewed 1611 times
