BT-1 Trigger unintentional flamming
owenthesheppard
Post by owenthesheppard »
Hi all
When using the BT-1 trigger bars, plugged in to a single input on the edrumin 8 I am getting flammed triggers every 5 - 10 hits
Sometimes it can happen multiple hits in a row. Sometimes I can go for 10-15 seconds with it happening but eventually it always happens.
This obviously is undesirable as it triggers two notes/sounds in quick succession making a flammed sound.
I'm using it as extra trigger inputs for my Roland SPDSX Pro, which only has four trigger inputs.
However, when I plug the BT-1 directly in to the Roland SPDSX Pro, the flaming goes away.
Any help is appreciated, this is really confusing me.
Re: BT-1 Trigger unintentional flamming
You probably need to dial in your settings. Have you watched this video?
https://youtu.be/v9_w32TWKZ0?si=3AWeKOE2U6p9t2x_
