Feature Request (or I'm just dumb, lol), with preset manager:
kevinbeckman1983
Post by kevinbeckman1983 »
Is there an easy way I'm missing to immediately see which preset is currently assigned, to the currently selected pad/input?
If not - is there a way an info/text box could be added to the preset manager, telling you which preset is active (if any)? So then when you open it, and/or change selected pads with the preset manager open, you know what preset is assigned to that pad already?
Apologies if asked and answered, but searching the forums with the term 'preset manager' gives back a lot of results.
Re: Feature Request (or I'm just dumb, lol), with preset manager:
The presets are stored on your computer, and are uploaded to the eDRUMin. The eDRUMin doesn't remember what preset was used. Sorry, the device just doesn't have enough memory for that kind of functionality.
kevinbeckman1983
Not a big deal, thanks for the reply ;)
