dsp trigger not installing
kappash
Post by kappash »
Hello, i run the .exe file (tried both normal run and administrator run), the installation seems fine but I get no exe in the install folder. No vst recognised by reaper. I'd like to buy it since i need this but i'd like to try it first.
System spec: i7 8700k, 32gb ram ddr4 gtx 3080ti. audio interface motu avb linked via adat to a motu 8 pre.
kappash
Re: dsp trigger not installing
Post by kappash »
You need to make sure you put the plugin (that dspTrigger.dll) into your VST2 plugins folder. There should also be a x64 dll, but I'm not sure where you put that. You can specify these paths when you run the installer. Just make sure you put them a path that Reaper normally scans.
kappash
Post by kappash »
hello, sorry if i took some time but i've been very busy. I was able to install and i was able to have the plugin talk with easy drummer. Problem is dsp keeps crashing reaper. I've opened 2 instances of dsp trigger one for each reaper track and i have been routing snare and bass drum input to a third track where i opened a easy drummer instance
