Sending MIDI to edrumin
bwclay
Post by bwclay »
I am using the Pearl Mimic Pro in conjunction with the EDI 10. I am using the aux/xtra inputs of the Mimic to send exisiting Midi notes to the EDI. I have maxed out the Aux and XTRA ports of the Mimic but still have some open in the EDI. Does anyone know another way to send MIDI notes to the EDI? Would I only have to send them via a laptop or another module?
Thanks!
Re: Sending MIDI to edrumin
I don't know your whole configuration, but you can daisy chain the USB MIDI with two eDRUMin units, so probably try to send the Mimic USB to the eDRUMin USB.
Then out to whatever you are using.
If using laptop, it will accept two USB inputs in any VST, just be sure to select both.
