BT-1 ISSUE
BT-1 ISSUE
The BT-1 is attached to my snare rim for x-stick only. I use the snare for head, rim only and rimshots. I have the bt-1 set to talk mode but when it hit the rim of the snare it triggers the bt-1. What no doing wrong. Shouldn't it only trigger when struck directly since it is using xtalk mode with a stereo cable? It should be only using the switch right? I'm confused. I read all theamual sections and watched the video. Thanks!
Re: BT-1 ISSUE
Sounds strange. From your destination, it should be working. Maybe try resetting the BT-1 input?
Re: BT-1 ISSUE
Ok. I'll try that. For now it works fine in sensor mode with some cross talk applied. I'll never probably be doing crossticls and snare hits at the same time anyhow.
