Does EdrumIn works without computer
Timico
Post by Timico »
Hello, my question is;
does EdrumIn, after calibrating with , for example, a PC windows computer, works with the made calibtrations as a - stand alone - ?
Does it ' memorise' the made calibrations ore does it need the computer as a brain to maintain the calibrations.
Thank you in advance,
best regards Gerjo
Re: Does EdrumIn works without computer
Timico wrote:
Sun Dec 10, 2023 2:29 pm
best regards Gerjo
Yes, yes and yes.
Yes, once configured, the device remembers its settings. ED4 and ED10 have a 9V DC barrel jack to power the device without a computer. For the ED8 you'll need to use a USB phone charger to power the unit (this method also works for the ED4 and ED10)
So as mentioned, you do not need to keep the app open for it to work with your settings.
