VH-13 pedal closed jumping from tight to open 6 when hit
Bassforlife2008
Post by Bassforlife2008 »
Just upgraded to a VH-13. When I am playing the hihatt closed I am hearing the pedal very quickly open up from tight to open 1 and upto open 6 very quickly producing open hits. In the video example my foot is firmly place all the way tight and you can see when i strike the hi hat it jumps to open 6 etc.
https://youtu.be/si2uMgxtdOg
Info;
Started with preset vh-13 Addictive drums
preset for vh-13 cymbal
did the calibrations
followed the video for vh-13 setup
confirmed placement on hi hat and no click is present when closing.
Messed with cross talk however kept ending up with no sound on fast playing.
Thanks for any help here!
Re: VH-13 pedal closed jumping from tight to open 6 when hit
Your polarity setting is set to 'auto', you might try changing that to 'Roland' and then recalibrating. Also if you are just setting up your hihat now, I recommend the latest BETA version which is available from the downloads page
Bassforlife2008
Thanks. updated to latest edrumin version and while I still see the jumps it is not producing the audio sample change to open when it occurs like before and sounds and responds way better. is the new firmware stable? I see the indicator. First time doing a firmware update on these.
Yes BETA is stable. For the official release I'm just going to update some default settings and update some factory presets.
