ED4 midi device not defaulting to checked in SD3
bpjacobsen
Post by bpjacobsen »
Not sure if this is a question for here or in the toontrack forums but will post in both. So I have 2 ED8 and an ED4. The ED8 boxes both always default to being enabled in SD3 Midi settings. But everytime I open SD3, I have to go into midi settings and check the box again to enable the ED4. Anyone know how to get this to stick so I don't have to enable it everytime?
Re: ED4 midi device not defaulting to checked in SD3
Definitely not an issue with eDRUMin software. But why don't you just connect the ED4 to the host port on one of your ED8s?
bpjacobsen
Wed Nov 22, 2023 12:43 am
I initially tried that but it was not showing up in the ED software. Also, at this point, I have all working other than the issues I mentioned. If I connect to a host port, will it mess up my midi mappings? Don't want to have to re-do them all again. I have a 4 port USB hub connected to the pc. it's not powered. but I don't think it will make any difference. I have ed8 to ed8 and I tried ed4 to the open ed8 usb port but the 4 was not showing up in the ED software. Only shows up when I connect it directly. Not sure what I'm doing wrong?
