Forum Topic Displaying
I seem to be having issues getting the sort function to work as expected. Ideally, when visiting the EDrumin forum, I would like to do a sort such that all topics with a recent posts appear at the top in descending order, based on the last post added to any given topic. I assume many of us are looking for that same functionality. Go to the forum and see what's ben most recently posted and scroll down do dive into earlier posts.
I have done the sort using the "descending" option, but it doesn't sort as expected. See attachments. One shows the settings I assigned to do a sort. The second is what is displayed after that sort. As you can see there are a mixture of posting dates and it's not sorted in descending order.
Am I doing something wrong? I'm sure it's something simple.
Thanks!
Screenshot 2023-10-24 at 3.21.34 PM.png (375.49 KiB) Viewed 817 times
Screenshot 2023-10-24 at 3.20.55 PM.png (70.07 KiB) Viewed 817 times
Re: Forum Topic Displaying
Looks correct to me. The topics at the top are 'Sticky' post that stay at the top. Perhaps I can remove some of them as they aren't so important anymore.
Tue Oct 24, 2023 9:29 pm
Aha, I was out of the loop for awhile. So the lightbulb-shaped icon designates the stickies. Below those, the topics are properly sorted.
Thanks for the quick reply, Rob!
