Disable Cymbal Choke
techministry
Post by techministry »
One of my Jobeky metal cymbals got bent on the edge and now sporadically it'll active choke while playing. Is there a setting in Edrumin to disable choke entirely? All notes and aftertouches, just as if the choke feature doesn't exist?
Re: Disable Cymbal Choke
Change the input to mono. You'll loose the edge through.
Cartman1227
Post by Cartman1227 »
techministry wrote:
Mon Oct 23, 2023 6:20 pm
Just suppress that particular PolyPressure midi event in a DAW :)
