USB Loopback not getting saved in VST
joshebosh
Post by joshebosh »
Hey Rob,
What do you make of this, possible bug?
I'm using FL Studio with ME VST
In VST this loopback setting will not save...
I have two presets, Drums (loopback disabled) and Synths (loopback enabled)...
The loopback param/variable will remain whatever i last toggled it to manually, regardless of which preset i choose, saved, resaved...
leading me to believe this particular value might not be getting reported to the values saved list?
example steps:
1 Disable the USB loopback
2 save a DAW VST preset like "Drums"
3 enable the USB loopback
4. save a DAW VST preset like "Synths"
5. load the "Drums" preset
6 the USB loopback will still be enabled, but should be disabled at this point
This does not appear to happen in standalone using Snapshot Manager
Only happens in VST
Re: USB Loopback not getting saved in VST
Thanks for the detailed report of the issue. Should be an easy fix. I'll look into it today.
Fixed. It's be available in the next update.
joshebosh
Post by joshebosh »
awesome, thank you!
It should be fixed in version 2.9.2.1, although I haven't tested thoroughly .
viewtopic.php?f=26&t=1981&p=13523#p13523
