Using 2 eDrumin's to trigger 2Box Module
Dainamo
Post by Dainamo »
Hello.
I picked up an eDrumin to trigger my 2Box module, was impressed with the results so I bought to go along with it for the rest of the pads. My eDrumin is triggering the 2Box with a Midi DIN cable, and it occurred to me that I'm unsure how to use 2 eDrumin's to trigger the one 2Box module.
I read the manual to see if I could find the answer but I guess I'm not quite understanding it well enough.
Is there a proper method for using 2 eDrumin's to trigger 1 module? Is it not possible?
Re: Using 2 eDrumin's to trigger 2Box Module
Assuming one of the eDRUMins is an ED8 or ED10, plug the second eDRUMin into its host port and the 2Box module to its MIDI out port MIDI from both eDRUMins will reach the 2Box module.
