Lemon T-950 Presets for AD2 (First Draft)
Forum rules
Danno
Post by Danno »
Hey all,
I'm dumping my current presets for the Lemon T-950 kit - These are a work in progress, but hopefully should get you in the ballpark. I am using AD2 as a backend sound source and currently use 2 Edrumin 8 units. Feel free to tweak, edit, and upload revisions as we get these dialed in - Please add revision info so we minimize confusion.
AD2_with_Lemon_T950_.edp
(572 Bytes) Downloaded 278 times
Danno
Re: Lemon T-950 Presets for AD2 (First Draft)
Post by Danno »
Toms (note Tom 1 & 2 are the same size pad so should be essentially the same)
LemonFlTom13.edp
(528 Bytes) Downloaded 278 times
Lemon10Tom2.edp
(528 Bytes) Downloaded 259 times
Lemon10Tom1.edp
(528 Bytes) Downloaded 285 times
Danno
Post by Danno »
Lemon Snare & 2 pc 12" HiHat
LemonSnare13.edp
(528 Bytes) Downloaded 266 times
LemonHat122pc.edp
(528 Bytes) Downloaded 281 times
