Link a edrummin 10 as add on to td27
redfax1
Post by redfax1 »
I’m using a td27 and a MacBook running superior drummer 3.
I want to add edrummin as I have filled the slots for pads on module.
How do I connect via midi?
Re: Link a edrummin 10 as add on to td27
If you are triggering in SD3, you have several options, but I would just connect the ED10 and TD27 separately (each via USB) to your computer, so no need for MIDI cables. SD3 can use multiple modules.
redfax1
Post by redfax1 »
thanks, Ill see if my macbook can cope with that
