RHH135 compatibility
jpm2112
Post by jpm2112 »
Hello Everyone,
I have searched through the forums and there doesn't seem to be a definite answer if Yamaha's RHH135 works well wirheDRUMin.
I am looking to use my RHH125 through eDRUMin trigger SD3 on Mac. Is there now a preset for the RHH135 or recommended settings?
Thanks in advance,
JP
Re: RHH135 compatibility
While I don't feel the RHH135 is the best of hihat controllers, it is supported. There isn't a specific preset for it, but the HH-65 preset should work just fine.
and if you want to have all levels of from close to open, disconnect the RHH135 controller, buy a square FSR, tape that to a board that slides under the HH pedal, stick a piece of foam on the FSR and connect the wires from the HH input on the eDRUMin to the FSR, no polarity.
Play with foam densities to get perfect feel.
Crazy simple and cheap, yet works amazing.
