eDRUMin 8 power supply
Does the eDRUMin 8 have a separate input for a 9v power supply like the 4 and 10? According to the specs it does not but I just wanted to make sure . Thanks in advance
Re: eDRUMin 8 power supply
No, it does not. You can power it with a USB charger though.
Ah, I did not think of that! Thanks a lot
I got my eDRUMin 8 and I love it. I am running it midi into a Mimic Pro. After I got all my triggers set up I used the Mimic USB to power the eDRUMin 8. Is this okay/
Thanks for the response
