VH12 set up edrumin4
nduk5
Post by nduk5 »
hi guys, im having issues setting up the vh 12 correctly using an edrumin 4 .
after selecting the vh12 presets, an calibrating the hi hat, im getting a few issues. the main one is when pushing down hard enough , it will automatically switch hi the hi hat cc mode, and sometimes it shows the bank change footswitch, this is all without me touching the edrumin interface, when this happen i have to recalibrate it otherwise when i press down on the hi hat, nothing happens. i have a video here:
https://imgur.com/a/hKPRXiz
anyone have luck with a vh 12 and an edrumin?
Re: VH12 set up edrumin4
There's a section in the manual about the VH_12. I'm away from my studio, otherwise I'd send you a link.
