ED10 not upgrading or downgrading
tjheller
Contact:
Post by tjheller »
No matter what I do I can't get the ED10 to upgrade/downgrade 2.1/2.2/2.3. I went from 2.1 to 2.3 once (on PC) and then somehow got it back to 2.1 after I started having trouble. (Midi stops after a few strikes on any pad in anything higher than 2.1) I can't troubleshoot the midi dropping because I can't successfully move between versions. I have 8 ED4s and I can upgrade and downgrade them all at will. I have no clue what I'm doing wrong. I've tried on Mac and PC, I've tried completely removing the program and starting with a fresh install. I'm NOT using a hub for any up/downgrading. I get the same error message on both Mac and PC. It says error, un plug and re plug your edrumin. Things actually work really well on the build of 2.1 that I'm using on the ED10 but I'd hate to miss out on future updates. I really can't imagine why I have no trouble with the ED4s either. Please Help.
Re: ED10 not upgrading or downgrading
We already resolved this right? The updating issue was related to your Alesis hihat controller, right?
