Edrumin compatibie with drum-tec pro 3 pads?
gkurtenbach
Post by gkurtenbach »
Is edrumin compatible with the new drum-tec pro 3 snare? Drum-tec recommends a PD-125 pad setting for Roland TD modules so I think it should be.
Has anyone tried it?
https://www.drum-tec.com/drum-tec-pro-3-snare-drum
Re: Edrumin compatibie with drum-tec pro 3 pads?
Their 3-layer mesh heads don't play well with eDRUMin (if you want positional sensing). If you can get it with. 2 layer head, then it'll probably work better. I recently picked up an ATV 13" snare, and it has quickly become my snare of choice.
gkurtenbach
I've got drum-tec's previous snare, the single head sensor version with a 3 ply head. Edrumin seems to track hit position ok. Is this an anomaly multi-sensor?
It would be great if Drum-tec sent you a Pro 3 snare for compatibility testing.
thanks!
Gord
