Bad eDRUMin control UI on Linux
Tarrasque
Post by Tarrasque »
Hi.
I'm using the latest eDRUMIn control software version available on the site (2.2.0 build 15) on Linux Ubuntu Studio 23.04.
The graphical UI seems to have some issues.
When clicking on the kit piece selection button(the one near the top right close to "Calibrate" the kit depiction appears misplaced.
Instead of being below the button it shows up (very small) over the Pad Type Selector button.
It appears clickable, but is pratically useless (the page buttons are trumped bu the Pad Type button clicks).
Re: Bad eDRUMin control UI on Linux
I can't reproduce the issue on my Surface Pro 3 running Ubuntu 20.04. Closing and reopening the app doesn't help?
Are you using a high resolution display?
Tarrasque
Post by Tarrasque »
I had already tried closing and reopening the app various time, with no avail.
I also tried switching from the newer Wayland video server to the classic X11, and nothing changed 8honestly I didn't see any difference in any programs I commonly use between the new servers).
Now I just booted up the PC and opened the control center again... and it shows perfect!
So, who knows what it was. Thank you very much for the prompt support anyway. I'll report again if I have any other glitches in order to help maybe iron out some bugs.
BTW, the system I use is a Lenovo IdeaPad Flex 5 convertible laptop, 1920x1080 touchscreen, AMD Ryzen 7 CPU and AMD Radeon GPU.
Thank you very much for your prompt support. It is very appreciated.
