Grey line not moving...
Rabidreject
Post by Rabidreject »
okay this one needs explaining....
So I am trying to set up the x-stick on my snare and its not working because the little line that moves around the green grey and black box just doesn't move side to side, therefore I cant get rimshots or x-stick.
The weirder thing is that sometimes it works and sometimes it doesn't - I am using a DDrum 14"x (I want to say 6?) snare shell with a Diamond drum centre trigger bar installed.
Is it the height of the trigger pressing against the skin thats wrong? I just don't really understand that and never have, I would say it is the thing in edrumin that needs improving the most because its really confusing...
Any ideas?
Re: Grey line not moving...
Can you hit the rim of the snare and then post a screenshot of your settings so I can have a look?
Also if it's really not moving, it probably means that your rim sensor is not working, or you have a bad cable or the cable is not completely plugged in.
Rabidreject
okay so the small 1/4" - 3.5mm jack cable wasnt in properly but its still not working or the line isnt moving. So I hit the rim as you said...
Screenshot 2023-05-19 at 11.44.19.png (354.18 KiB) Viewed 1788 times
no idea why, its very odd, im using SD3 as well. I'm just gonna try restarting everything quickly - you never know
Rabidreject
oh I meant to say - the dot you can see is where the rim is triggering the main centre piezo...
Rabidreject
I think my rim piezo is broken tbh... cant see any signal coming in on the right hand side....
Yup, the eDRUMin is not receiving any signal from the rim sensor.
