I downloaded DSPTrigger because i thought i could use it but i think i understood it wrong.
How can u remove it from my mac? I don't see any uninstaller and can't find where it is installed
Thank you
Uninstall on mac
Re: Uninstall on mac
The installer adds the plugins in the following locations:
Additionally, if you have no other Audiofront software installed, you can delete the hidden .Audiofront folder from your user folder. On my system it's located at:
Code: Select all
/Library/Audio/Plug-Ins/Components/dspTrigger.component
/Library/Audio/Plug-Ins/VST/dspTrigger.vst
Code: Select all
/Users/robert/.Audiofront
