2 edrumin4s or an eDrimin10?
I have 2 eDrumin4s. Just wondering if consolidating to an eDrumin10 would be beneficial for the computer (macOS) to process or for latency (if any) OR doesn't make a difference?
Would be nice to have 2 more inputs that i could use.
Re: 2 edrumin4s or an eDrimin10?
Other than getting another 2 inputs and USB host port, the ED10 would not affect you computer's ability to process the MIDI data and latency. Latency depends on your audio interface settings.
Denis
Post by Denis »
Does that mean I have the same latency either when combining the eDRUMin4 with an eDRUMin8 or just using one single eDRUMin10?
Yes, the latency will be the same.
Denis
Post by Denis »
Sat Dec 16, 2023 9:29 pm
Thanks for the fast response :D
