HatKat and FatKat pedals
griotspeak
Post by griotspeak »
Hello,
I have two pedals, both of them are old Alternate Mode Pedals (pictures below for clarity are from reverb but are the correct models)
Will these both work 'as intended' with MIDI Expression Quattro or should I wait for the edrumin 10, which I am interested in beside this pedal question, to be restocked? I would eventually prefer to use an edrumin 10 because I have additional triggers to use but that's a couple months out and, if the Quattro works with these pedals, it would provide a nice alternative when I don't need extra triggers.
Re: HatKat and FatKat pedals
If they use piezos then you will need to use an eDRUMin to support those pedals.
griotspeak
Thank you for the quick response
