DrumMaps
Forum rules
BenoitL
DrumMaps
Post by BenoitL »
Hello
I didn't find the DrumMaps factory Presets in my eDrumin > How can I do ? Is there a way to download it ?
Capture d’écran 2022-12-23 à 15.36.06.png (293.44 KiB) Viewed 7222 times
Capture d’écran 2022-12-23 à 15.35.57.png (439.66 KiB) Viewed 7222 times
Capture d’écran 2022-12-23 à 15.36.32.png (274.46 KiB) Viewed 7222 times
Re: DrumMaps
You're on macOS right?
BenoitL
Re: DrumMaps
Post by BenoitL »
Yes - on monterey
Re: DrumMaps
I'm on vacation for a few more days, so I'll unable to confirm the location of the presets or confirm if there is an issue with the installer until I get back. I'll post here when I get a chance to test.
BenoitL
Re: DrumMaps
Post by BenoitL »
ok !
Re: DrumMaps
So I uninstalled, deleted any eDRUMin related folders and reinstalled. I can confirm that the drumMaps are installed properly and they should be located in the following folder on my system:
Code: Select all
/Users/robert/.AudioFront/eDRUMin/factory/drumMaps/
BenoitL
Re: DrumMaps
Post by BenoitL »
mhmm... I will erase all and re-install
Capture d’écran 2023-01-02 à 16.12.52.png (428.7 KiB) Viewed 7172 times
I tell you if OK
Thank you
BenoitL
Re: DrumMaps
Post by BenoitL »
Its ok
I have install in another computer, then copy the folder you show me
And now, I've got the map in my interface
Thank you !
