(2) Since gig performer is overwhelmingly visual it'd be a lot easier to discuss this with image upload turned on, as it is in some other forums here. Would this be possible
![Question :?:](./images/smilies/icon_question.gif)
(3) So far, with the VST plugin, I've made the obvious connections, and things work if I hit the bug GUI drum pad in the DSP Trigger UI, but I can't get an actual drum hit to trigger that, which just worked automatically in MainStage. The waveform and bars do work when I make a hit.
