File import/export
Mr_Bluesguy
File import/export
Post by Mr_Bluesguy »
I have a rack mount stage pc for live performance and take a backup laptop along for emergencies. So any changes made in edrumin settings on the main pc need to be added to the backup pc.
My question is if there is a a way to take a "global" snapshot of ALL of the input information at once and store it to a file, which could be imported by the back up pc, or is it only possible to store each input's data (user pre-set) individually? So basically importing one file instead of 14 individual ones in my set up.
Thanks
Re: File import/export
What version of the control application are you using?
Assuming you are using a recent version of the control application, you can save device presets from the preset manager.
Preset Manager
Mr_Bluesguy
Yes, I'm using the latest version. After reading in the manual, my understanding was that each input can be saved to its its own pre-set. So you are saying that saving a single pre-set covers all of the inputs?
Mr_Bluesguy
Also, I am using both ED10 and ED4. Do I save a pre-set for each device?
Click on a device icon, and you can save a device preset ED10 and ED4 will need to be saved as seperate device presets.
Mr_Bluesguy
Awesome. Thanks!
