eDRUMin version 2.1.1 BETA
eDRUMin version 2.1.1 is available for testing. You can downgrade from version 2.1.1 to version 2.1.0.x without having your device reset. This version fixes a few small bugs and aims to improve support for metal cymbals.
eDRUMin_Control_PC_2.1.1.5.zip
eDRUMin_Control_OSX_2.1.1.5.zip
eDRUMin_Control_LINUX_2.1.1.5.zip
New Features
  • 3-Zone Metal Cymbal can use set the bell input as piezo or switch.
  • Dual Zone Metal Cymbal can now used piezo/switch or piezo/piezo configurations.
  • Metal cymbals that use piezo for the bell sensor can use the bell signal to calculate the velocity of the bell note.
Improvements and Bug Fixes
  • Simplified the pedal modes for sustain and footswitches.
  • Resetting a 3-Zone Metal cymbal will now properly restore the bell input.
  • Improved the reliability of compatibility tests.
  • Changing the input mode of a 3-Zone input will now properly release its helper input.
  • Meters for cymbal articulation scalers are now working again.
  • Prevent sending presets to bell inputs.
Re: eDRUMin version 2.1.1 BETA
Experienced a crash when attempting to switch my cymbal from 3-zone to 2-zone (which worked fine otherwise.)
Crash report attached.
edrumkn_crash.txt.zip
(8.73 KiB) Downloaded 146 times
Hi Monospace,
Couldn't reproduce. I don't see why it crashed, but I did some extra sanitation there jic.
Changes in build 3
  • Updated manual.
  • Fixed some UI manual links pointing to the wrong pages in the manual.
  • Prevent setting an input to an input type that uses a helper input if its adjacent input uses a helper input.
  • Prevent sending presets to helper inputs.
That version's no good, it crashes immediately on open.
edrumin_crash.txt.zip
(8.48 KiB) Downloaded 157 times
embarrassing...posted build 4
I found a small bug. Factory resetting the entire device doesn't fully release helper inputs. I've fixed it for the next build. As a workaround, you can save after you reset and then power cycle the unit.
That version works, thanks. I'm able to switch between 2 and 3 zone cymbals with no problems (was just curious, although I'll keep my Lemon on the 3-zone because it just works better that way.)
Another thing I noticed: clicking on the PDF button ("Open Manual") does nothing?
Finally, in the category "not a bug at all just noticing", the Dock icon on MacOS is bigger than other dock icons.
Screen Shot 2022-11-15 at 5.54.41 PM.png (177.16 KiB) Viewed 2134 times
Mr_Bluesguy
Post by Mr_Bluesguy »
Found a small glitch in 2.1.13. Each time edrumin is opened, articulation notes are displayed as music notes, not midi notes, despite having specified them as midi notes in the "advanced mode" menu. That choice doesn't appear to be saved.
Mr_Bluesguy wrote:
Wed Nov 16, 2022 6:41 am
I can't reproduce that issue here. Are you on Windows or Mac?
Mr_Bluesguy
Win 10
