A couple of questions about hihat settings when using sd3:
- is it generally better to use the 'edrum optimised' setting in sd3 for 'openness transitions' rather than the edrumin fixes? ('fast stepping' fix and (no) 'cc with hit')?
- should I disable the 'hihat cc edit' option in sd3? (if it's enabled in sd3 - which it is by default - the cc transition positions will be 'double' processed by the edrumin settings and then sd3 making it harder to judge what's happening from the edrumin pedal visualiser?)
Optimum settings for superior drummer 3
Re: Optimum settings for superior drummer 3
I suppose a lot of it will depend on your specific hihat trigger, but for what it's worth, all my SD3 "openness" settings are default. I find that I get much better results tweaking only the controls inside the eDRUMin app. I'm not noticing any overhead when CC mapping is enabled, so, again, I don't mess with that either. In general, I leave my drum software alone when it comes to trigger settings, that's what eDRUMin is for after all.
I'm using a Drone optical hihat sensor, so YMMV. Hope this helps.
Seconding Monospace's approach. My HH, again optical, is fantastic using default SD3 settings.
Yeah, in general any tweaking I do in SD3 is about shaping the sound, not the triggering.
Me too,
using a Hall sensor.... SD3 defaults. And I am fine.
