DIY triggers - which PAD Preset is best?
Hi all,
My DIY trigger configuration is 3 edge triggers 120 degress apart for rack toms and floor toms, wired parallel as Roland (sleeve - ceramic, brass -tip), single zone (no rim). Mesh heads are double ply
Will be doing a dual zone head and rim) snare same configuration.
Any suggestions on which Pad preset would be best suited for this type configuration?
thankx
Re: DIY triggers - which PAD Preset is best?
If you look in the latest BETA thread, you'll see that version 2.1 now has a Mesh 3 side sensor pad type.
aaah great Rob Thankx
wondering if the multiple points detected on the transient are coming from all 3 triggers?
but my 16" floor tom is clean with 1 detected vs the 14".... interesting
